12 years agoHow to keep all top level signals for mapping to pins (feasibility study)
Hello, For a feasibility study, I have to see if we can use a certain FPGA. Mainly seeing if we can fit all the needed signals on the pins. For that I took another project on which the new...
12 years ago --- Quote Start --- Thanks for your extended explanation, I'm quite new to this and this is really helpful. --- Quote End --- You're welcome. --- Quote Start --- For this new project we want to go further from another project. But now with interface Y instead of interface X, more memories... In theory we have enough pins but it's close. Therefore, I wanted to check this with the pin planner. I removed all code from this old project and changed the top level interface. Adding more and more pins with some basic code or a megawizard design behind it. Some things got synthesized away and to prevent this, I created this thread. In the meanwhile I got to know virtual pins which also helped preventing things from getting synthesized away. --- Quote End --- Another way to stop the synthesis tool from removing components is to use synthesis constraints (keep and no prune). Though eventually its better to create a design that works, eg., a Qsys system, add stuff to that system, simulate it, and then synthesize it. At least then you can be 100% sure your resource estimates are legitimate ... unfortunately it requires more effort. Cheers, Dave
