9 years ago
how to interface an ADC with 3 wire SPI (bidir SDIO) to Qsys ?
I need to connect the SPI port of an AD9266 ADC to a Cyclone 5 SoC. This is a 3 wires SPI : clock, CS and bidirectional data (SDIO).
Can I have some hints ? I see that the QSYS SPI module supports only 4 wire SPI. Do I have to write my own vhdl module and
then interface it to QSYS ? Considering that this is probably a common problem, does someone has an example ?
Franco
    It might not be possible to make the QSPI controller behave like a generic bidirectional SPI controller since it's intended for QSPI flash devices and not I/O like an ADC. I do not believe Qsys comes with a bidirectional slave controller but it shouldn't be much effort to create one from scratch especially if you build it just for the ADC you have in mind.
    Franco,
    The cyclone HPS SPI won't allow you to properly access the AD9266.
    It implements the SPI standard with two uni-directional bus "wire": MOSI and MISO and neitehr of them can be set bi-directional.
    If you are ready to go through a lot of pain, may be the QSPI could be used.
    In a single lane configuration, the QSPI the same SPI 2 uni-directional bus "wire".
    But in dual or quad lane, the bus becomes 2 ror 4 bi-directional "wire" for the data transfers and only for the data.
    You'll need go through a lot of hoop and loops trying to spoof the QSPi protocol to
    FPGA is one safe way to go...
    BUT!!!
    Yes there is a but! :-)
    Using the SPI, you can put an open collector or open drain chip + a pull-up resistor between the SPI MOSI line and the ADC data line.
    The you connect the ADC data line directly to the SPI MISO.
    I think that should do the job if you properly program the SPI controller & send all 1's when reading.
