ALane's avatar
ALane
8 years ago
How to Infer a ROM's Contents from a file?
I'm trying to convert a Xilinx design onto a Cyclone V and am struggling with the Intel documentation on how to infer a ROM where its contents are provided by an external mif file​. Looking at the documentation this idea does not seem to be covered. (i.e. the examples all appear to generate the ROM contents within the hdl files)
Here is a snippet from the code I am trying to re-use:
impure function init_mem(mif_file_name : in string) return T_ROM_TYPE is
file mif_file : text open read_mode is mif_file_name;
variable mif_line : line;
variable temp_bv : std_logic_vector(G_DATA_WIDTH-1 downto 0);
variable temp_mem : T_ROM_TYPE;
begin
for i in T_ROM_TYPE'range loop
readline(mif_file, mif_line);
hread(mif_line, temp_bv);
temp_mem(i) := temp_bv;
end loop;
return temp_mem;
end function;
-- ROM array constant
constant rom : T_ROM_TYPE := init_mem(G_ROM_INIT_DATA);
begin
-- ROM read access control
rom_cotrol_proc : process (CLK)
variable address : integer range 0 to ((2**G_ADDR_WIDTH)-1);
begin
if CLK'event and CLK = '1' then
if IP_EN = '1' then
address := to_integer(unsigned(IP_ADDR((G_ADDR_WIDTH-1) downto 0)));
OP_DATA <= rom(address);
end if;
end if;
end process;
  • You could initialize the memory using MIF file or Intel HEX file. I would suggest you replace your ROM code with one of Intel's 1-port ROM Megafunctions. When you use the megafunctions, there's an option to initialize the memory using MIF or HEX files.
    Migrating the small ROM/RAMs to using Intel megafunctions may help resolving such issues.
    -Abraham
  • ALane's avatar
    ALane
    Thanks for the answers!
    Looks like I'll try the mega function where I can at least setup the ROM dimensions/contents via generics.
  • Abe's avatar
    Abe
    -Abraham
  • Tricky's avatar
    Tricky
    Unfortunately, Quartus has been lacking the ability to infer the ram contents using textio for years - I raised an enhancement request on this 10 years ago - afaik this is still not possible!!!!
    You can use the ram_init_file attribute to read the contents of a .mif file during synthesis, but it wont load it during simulation. The only way to load it during simulation is with an init function (like the one you posted - but this only would need to be removed from synthesis) or by using the altsyncram megafunction and specifying an init_file generic to the .mif file
