How to include custom onchip memory block into the Linker section mappings ?
Hello, I have a custom onchip memory (block memory) with a avalon slave interface. I want this to show up in the linker section mappings of eclipse SDK. So, that i will use this to load rodata,heap, stack (use it as code memory). I observed that on-chip memory has got attribute named "memory " and jtag-uart has got "printable" attribute. what additional things to do to my custom logic so that it can be seen in linker mapping section.
--- Quote Start --- You need to edit your IP's *_hw.tcl file with a text editor. Find the section describing the Avalon Slave interface for your memory component, that should be like this:
(where iname is the name of your avalon interface) And add a parameter in the list:# # connection point iname # add_interface iname avalon end
replacing iname with the name of your interface. Then regenerate the QSys project and recompile. --- Quote End --- Hehe !!! Worked This is exactly what I want I can now select my peripheral in linker script pulldown menu. Trivial thing is ,In settings.html file attribute name is empty. Thank youset_interface_property iname isMemoryDevice true - Altera_Forum
replacing iname with the name of your interface. Then regenerate the QSys project and recompile.set_interface_property iname isMemoryDevice true - Altera_Forum
I tried it , but it says error something like- memory block withe the name "my custom logic" not found in sopc design. I explored the .IP file of onchip that taken from IP catalog and compared with .IP file of my custom logic. I can see there are certain .xml like lines in the ip file
Like IsMemoryDevice =1 in alteration ocm and it is zero in my case. I am thinking in this direction. - Altera_Forum
In the BSP editor, add it as a new section to the Nios memory map.
