11 years agohow to fix varying pwm along with constant frequency of 20kHz in cyclon 2 ep2c5t144c8
Hi! I am using ALTERA cyclon 2 ep2c5t144c8n board for generating varying pulse width modulation (duty cycle from 0 to 100%) along with constant frequency of 20kHz. I have written the code and its wo...
11 years agoCode:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity pwm_sti is Port ( clk : in STD_LOGIC; reset : in STD_LOGIC; feed_back : in STD_LOGIC_VECTOR (7 downto 0); driv1_out : out STD_LOGIC; driv2_out : out STD_LOGIC; pwm_out : out STD_LOGIC); end pwm_sti; architecture Behavioral of pwm_sti is signal counter_166, counter_166_delay : unsigned(7 downto 0); signal count_2500clk_cycles : unsigned(11 downto 0); signal pwm_comp_reg : unsigned(11 downto 0); signal count_pwm_comp_reg : unsigned(11 downto 0); signal delta_reg : unsigned(7 downto 0); signal driv1_out_sig, driv2_out_sig, state_falg : std_logic; signal counter_1div60_div4, counter_1div60_div4_delay : unsigned(1 downto 0); begin driv1_out <= driv1_out_sig; driv2_out <= driv2_out_sig; -- pwm generation process process(clk) variable pwm_comp_var : unsigned(12 downto 0); begin if(clk'event and clk = '1')then if(reset = '1') then counter_166 <= (others => '0'); counter_166_delay <= (others => '0'); count_2500clk_cycles <= (others => '0'); pwm_comp_reg <= (others => '0'); count_pwm_comp_reg <= (others => '0'); delta_reg <= (others => '0'); driv1_out_sig <= '1'; driv2_out_sig <= '0'; counter_1div60_div4 <= (others => '0'); counter_1div60_div4_delay <= (others => '0'); state_falg <= '0'; else pwm_out <= '0'; if(state_falg = '0') then delta_reg <= unsigned (feed_back); state_falg <= '1'; else if(count_2500clk_cycles = "100111000100") then count_2500clk_cycles <= (others => '0'); counter_166 <= counter_166 + 1; -- adding value to pwm comp reg if(counter_1div60_div4(0) = '0') then pwm_comp_var := resize(pwm_comp_reg, 13) + resize(delta_reg, 13); pwm_comp_reg <= pwm_comp_var(11 downto 0); elsif(counter_1div60_div4(0) = '1') then pwm_comp_var := resize(pwm_comp_reg, 13) - resize(delta_reg, 13); pwm_comp_reg <= pwm_comp_var(11 downto 0); end if; -- after half sine cycle if(counter_166 = "10100110") then counter_166 <= (others => '0'); driv1_out_sig <= not (driv1_out_sig); driv2_out_sig <= not (driv2_out_sig); pwm_comp_reg <= (others => '0'); end if; elsif(count_2500clk_cycles = "100111000011") then count_pwm_comp_reg <= (others => '0'); count_2500clk_cycles <= count_2500clk_cycles + 1; else count_2500clk_cycles <= count_2500clk_cycles + 1; if(count_pwm_comp_reg <= pwm_comp_reg) then count_pwm_comp_reg <= count_pwm_comp_reg + 1; pwm_out <= '1'; end if;-- count_pwm_comp end if; -- 2500clk -- creating a delay counter_166_delay <= counter_166; if ((counter_166 = "01010011" and counter_166_delay = "01010010") or (counter_166 = "10100110" and counter_166_delay = "10100101")) then counter_1div60_div4 <= counter_1div60_div4 + 1; end if;-- counter_166 -- creating a delay counter_1div60_div4_delay <= counter_1div60_div4; if(counter_1div60_div4 = "00" and counter_1div60_div4_delay = "11") then delta_reg <= unsigned (feed_back); end if; --counter 1 div 60 div 4 end if; -- state falg end if; --reset end if; -- clk end process end Behavioral;
