14 years agoHow to Find ADC Converter
hello...anyone can help me how to find ADC comverter which can supported 2 sensor and using SPI interface to altera de 2 board...plzz help me..
orite... MCP3004 can joined with 2 sensor??i user water level sensor and flow rate sensor??
Well...
in fact there are many chips communicating via SPI I/F with different input signal ranges, resolutions, number of channels,... "on the market". So far you did not specify which type of sensor you want to connect (or best which kind of analog signal (range, frequency, source impedance) you want to convert nor do we know which sample rate and bitwidth is required in your design... If there is no high sampling rate required I'd go with cheap ADC of e.g. Microchip (e.g. the MCP3004), if you need higher sample rates, take a look at analog device. At least any of these manufacturers have a "downselection" option, i.e. you can define the parameters you require and they suggest matching devices based on your requirements - this might be the best and easiest option... That's just my humble opinion - there are many other ADC manufacturers (and I do not get money to suggest Microchip and Analog at all ... :) ) Regards - Altera_Forum
what do mean about ideal??
how about your ideal?
which converter should i use?
