12 years agoHow to enable dual core cortex A9 mode of Cyclone V?
I have used Cyclone V in Single Core configuration but i don't know how can use it in Dual core mode. I have checked the reference manual where i can only see HPS Info Register. This register indic...
12 years agoThe second core does not execute any instruction when the first core send an IPI for task scheduling. Second core is stopped at instruction "S:0xFFFF0100 : LDR sp,[pc,#-164] ; [0xFFFF0064] = 0xFFFFE6A4". So in reality the first core bear all the load. The same code is working fine on i.MX6 on 2 cores. What could be the difference?
P.S. I am using DS-5.- ALTERA-INSUPPORT222 years ago
@Altera_Forum Did you find the solution? I am also facing the same situation.
I combined two bin files, core 0 also taking core 1 out of reset, but the problem is core 0 program counter is fine and in range after 0x60000 showing it work fine as in linker its entry point is 0x60000 but core 1 program counter goes to 0xFFFF0004 but its entry point in linker file is 0x100000
