14 years agoHow to disable vrefb pins in quartus?
Hello All,
I have routed a 3.3v to VREFB1N0 in cyclone IV. However,now,I am no longer needed that voltage reference. So,should I disable the voltage reference pins? If yes,how can I do it?By changing that pin to output pins? Hope to hear from any of you sooner. Thanks3 Replies
Since VREF pins are usually I/Os also, make them inputs.
Thanks for the explanation. To be frank, I was connecting the vref wrongly and somehow that bank does not working as expected(leds connected to that particular bank light up when they are supposed not to be)
That's why I was wondering if it has something to do with the wrong voltage assignment on that bank vref - Altera_Forum
The questions seems to be based on wrong assumptions.
The VREF pins are used for voltage referenced I/O standards like SSTL with DDR RAM. Their function is automatic and don't need specific assignments (of course, they must not be configured as outputs when used as a reference input). Unused Vref pins are treated similar to unused regular I/Os, sharing the global unused pin policy. I can't imagine a reason to connect Vref to 3.3V.
