15 years agohow to design the system using SSRAM CY7C1470V33 in the sopc builder
HI we are using the SSRAM CY7C1470V33 in our design (instead of CY7C1380C which is part of the SOPC builder). How do we go about designing the system . Please help us regards, Bhandari
14 years ago --- Quote Start --- This component doesn't work with QSys. Apparently anything using an Avalon MM tri-state buffer needs an upgrade. It ask you to perform the upgrade, which i do and it doesn't change anything. --- Quote End --- QSys has a few extra features compared to SOPC. Check if the upgraded component defines all the required interfaces and if all ports are correctly connected. Also check the base address: I can't remember right now if your SRAM component must be assigned to an absolute address or offset from TS bridge. For more help you must specify what your problem exactly is: can't build Qsys? SRAM doesn't work at all? you can access SRAM, but you get data errors?
