15 years agohow to design the system using SSRAM CY7C1470V33 in the sopc builder
HI we are using the SSRAM CY7C1470V33 in our design (instead of CY7C1380C which is part of the SOPC builder). How do we go about designing the system . Please help us regards, Bhandari
15 years agoNotepad or any editor. It's a simple text file.
For a 512k sram you'll need to change at least add_interface_port avalon_tristate_slave addr address Input 19 (I used 16 because a simply had a 64kB device) You can initially mantain unchanged the other parameters. Probably this is enough for your first tests with CY7C1470V33. You can then adjust wait cycles to improve access time performance. Regards
