15 years agohow to design the system using SSRAM CY7C1470V33 in the sopc builder
HI we are using the SSRAM CY7C1470V33 in our design (instead of CY7C1380C which is part of the SOPC builder). How do we go about designing the system . Please help us regards, Bhandari
15 years ago --- Quote Start --- How do I edit the file so that it is compatible with SRAM 512kb on de2 board? --- Quote End --- You must change what is needed to meet your system specification. If bus width already matches, you mainly must only adjust wait states so that they comply with your sram speed (you must refer to sram datasheet). Then you possibly want to change component name or other parameters.
