15 years agohow to design the system using SSRAM CY7C1470V33 in the sopc builder
HI we are using the SSRAM CY7C1470V33 in our design (instead of CY7C1380C which is part of the SOPC builder). How do we go about designing the system . Please help us regards, Bhandari
15 years agoYou can simply write a simple tcl file which defines your component parameters.
I attached a sample. Change the required parameters and possibly the name to match your sram and copy the file into the altera\<your version>\ip\user_components directory. If you change the file name, keep the _hw.tcl suffix, otherwise sopc builder will not find it. When you refresh the component list in sopc builder, you should find the new sram component in the sram section Regards Cris
