8 years agoHow to design ALM for Aria 10?
I have two simple 5-input and 3-input functions in Verilog. Function 1: 3:1 Multiplexer input a,b,c; input [1:0] s1; output wire east; Function 2 : 2:1 Multiplexer input d,e; ...
8 years agoWhat is your goal here? Are you concerned about resource usage? Yes, the compiler should be able to do what you are referring to. Are you looking at the Fitter compilation report or just synthesis? If it's just synthesis, it's not optimized yet for actual resource use.
