14 years agohow to describe same block in Demux in VHDL
I am having problem in describing a 1 to 2**n Demux. I wrote code first for 1 to 2 demux,and use it to buid 1 to 4 demux and then 1 to 8. At the end I want to get a 1 to 2**n demux. they are shows on...
14 years ago --- Quote Start --- I would rather appreciate if anyone give me some advice to use generate or others to describe it. --- Quote End --- Here's a mux. Wrap your head around the logic, and you can figure out how to describe a demux :) The comments in the code described it fairly well. The PDF is a figure to help describe the indexing. Cheers, Dave
