16 years ago
how to "cut" a vector...
hi guys, i have small question.
you see i got this project and i need to build this unit , which receives "packages" in serial communication mode (also i need to know how to do it for parallel communication mode ,for the final exam). the package structure is like that : first 3 bits are address, next 3 bits are number of "data" received , and the last 8 bits are the "data".
now everything comes in one "package" . the question is how can i divide the vector into : 3,3, 8 ? and save only the last 8 bits into a fifo component ?
thanks in advance
    thanks guys , and the last question how do i add them all after i finish doing some operations on them , do i use the "&" sign or the "+" sign ?
    like :
    data :out std_logic_vector ( 13 downto 0 );
    data<= address (13 downto 11) & datanum (10 downto 8) & (7 downto 0);
    Yes, the bit order of your input vector may be different, however. With numeric data, a descending data direction is usual, as you wrote above for data_in. It's more clear, if you use the same direction for all involved signals, e.g. all_vector(13 downto 0). Serial data streams that are shifted in can still be LSB or MSB first, so it's best to specify clearly the bit allocation of each sub vectors. I would expect this as a standard:
    address <= all_vector(13 downto 11);
    datanum <= all_vector(10 downto 8);
    data <= all_vector(7 downto 0);
    wait let me understand , if i got : data_in : in std_logic_vector( 7 downto 0) and i want to slice it to 5, and 3 : so i need to write : data1<=allvector(7 downto 3) and data2<=allvector( 2 downto 0 ) ?
    The number of bits doesn't fit your example...
    The last 8 bit's can be accessed like
    data <= allvector(7 to 14);
    The expression is called an array slice in VHDL terminology.
    You don't tell your what's your HDL entry method. Each language has simple constructs to access array slices, it's also easy in schematic entry.
