16 years agohow to "cut" a vector...
hi guys, i have small question. you see i got this project and i need to build this unit , which receives "packages" in serial communication mode (also i need to know how to do it for parallel co...
16 years agoThe number of bits doesn't fit your example...
The last 8 bit's can be accessed like data <= allvector(7 to 14); The expression is called an array slice in VHDL terminology.
