In case anyone else runs into this problem, I thought I'd share what I've figured out so far. This is probably stuff that an experianced windows programmer would know...but I'm not one of those :D
It appears that when you are making a windows application in MS visual studio you need to compile with "Pure MSIL Common Language Runtime Support (/clrpure)". However, you can force the compiler to use the decorated name you want. In this case, the DLL contains decorated names using __cdecl. The solution is go into the header file (my_jtag_atlanitic.h) and place __cdecl in from of all the function names. This will force the comiler to use the name that you want. so the original header file looked like this:
typedef struct JTAGATLANTIC JTAGATLANTIC;
JTAGATLANTIC * jtagatlantic_open(const char * chain, int device_index, int link_instance, const char * app_name);
enum JATL_ERROR jtagatlantic_get_error(const char * * other_info);
void jtagatlantic_close(JTAGATLANTIC * link);
int jtagatlantic_write(JTAGATLANTIC * link, const char * data, unsigned int count);
int jtagatlantic_flush(JTAGATLANTIC * link);
int jtagatlantic_read(JTAGATLANTIC * link, char * buffer, unsigned int buffsize);
this will result in lots of linker errors as specifided in a previous post. we can add the __cdecl modifier in front of the function names as follows:
JTAGATLANTIC * __cdecl jtagatlantic_open(const char * chain, int device_index, int link_instance, const char * app_name);
enum JATL_ERROR __cdecl jtagatlantic_get_error(const char * * other_info);
void __cdecl jtagatlantic_close(JTAGATLANTIC * link);
int __cdecl jtagatlantic_write(JTAGATLANTIC * link, const char * data, unsigned int count);
int __cdecl jtagatlantic_flush(JTAGATLANTIC * link);
int __cdecl jtagatlantic_read(JTAGATLANTIC * link, char * buffer, unsigned int buffsize);
this modification makes the compiler use the names that match with what's in the DLL.
I still get the following compiler warnings:
warning LNK4248: unresolved typeref token (01000014) for 'JATL_ERROR'; image may not run
warning LNK4248: unresolved typeref token (01000015) for 'JTAGATLANTIC'; image may not run
these sound a little scary, but the application seems to run fine. The Jtag link is established when I bring it up. I've hit another problem that is crashing my program before I can actually send or receive data, but I don't think it's related to this. I'll update the forum when I get that far.
I had to search around on MSDN for figure this out. I think this link had most of the explanation:
http://msdn.microsoft.com/en-us/library/ms173253.aspx
