17 years agoHow to create a simple program that behave like a Nios IDE?
Good Morning I have NIOS development board and I created a simple NIOS setup with memory and JTAG UART & LED. I already purchased the NIOS license so I have unlimited test time. I also use the...
17 years agormatsick and cooi23,
I'm experiancing similar problems to what cooi23 alluded to with console vs. windows applications. cooi23, did you ever solve that? It looks there is a difference in the full function names. If I do a dumpbin on the obj file for the console application, the full names of the functions begin with with __cdecl. those are the ones that work. dumping the obj file for the windows application show the function names starting with __clrcall. I believe that's why it won't link. It's looking for a different name than the dll/lib provides. I haven't found a way to make it work yet. the project that works is set up for "No Common Language Runtime support". The windows application is set for "Pure MSIL Common Language Runtime Support (/clr:pure)". I think this is the driving factor, but I haven't figured out how to force the windows app to use the __cdecl naming. any input?
