12 years agoHow to create a *.mif (Memory Initialization File) from a picture (*.bmp)
Hello I' am trying to make a *.mif (memory initialization file) from a picture(gray scale) and initialize it with memory i have create in fpga. The memory is reg [7:0]...
12 years agoThe easiest way is to use the megawizard to create a ROM/RAM block. Then you can specify the .mif file to use for the block contents.
