15 years ago
How to control clock frequency?
I create a D flip flop with positive edge input clock. when I do pin assignment for the input clock, which is PIN_N2, I have no idea how to manipulate the clock frequency. May I know how to control the clock frequency?
thanks!
    You have to add some VHDL code that uses a counter to divide the clock.
    For example you create a counter (in VHDL) with the clock as inputclock that counts to a million (or more). And once the counter reaches a million you change the state from the LED (so on or off).
    A PLL is too complex for this purpose and I doubt that is what you want/need to do.
    So something like this (this is AHDL, with probably some syntax errors):
    SUBDESIGN counter
    clock : INPUT;
    LED_OUT : OUTPUT;
    VARIABLE
    count[20..0] : DFF; //create a counter that can count to 2^21-1 =1048576
    LED : DFF; //help flipflop
    BEGIN
    count[].clk = clock; //link clocks
    LED.clk = clock;
    count[].d = count[].q+1; //start counting
    If Counter[21].q==1 Then
    LED = not LED; //change state
    Counter = 0; //reset counter
    end if
    LED_OUT = LED; //Link help flipflop to output
    END;
    I hear from your answer, that you already have a clock source connected to your FPGA. You have to divide the input frequency to get a visual result. The timing analyzer doesn't change a clock frequency. A PLL or a counter can.
    Thanks for reply.
    May I know timer analyzer can use to control the clock frequency? I want to see the blinking leds from the output counter in bits on de2 board. but they run too fast and I don't know how to adjust the output speed.
    thanks!
    Without placing an external clock generator, usually a crystal oscillator, there is no clock frequency.
