14 years agoHow to constraint my design using TimeQuest?
I am looking for some help to constrain my design. I've never done a timing constraint and my understanding of the subject isn't very deep at all. An overview of my design: it consists of a 72 ...
14 years agoThat's a good test: change the speed of sys_clk vs SCK.
This way, you can pin-point which interface is giving you problems: the PO/PI or the SPI interface. Also, if the situation improves when you lower the operating frequency, there are two main possibilities. One, you have a setup timing problem. That means, some signal is taking too much time to become stable and, occasionally, it's samples before it has becomes stable. But again, with a 7 ns rise time I don't see that happening. Another possibility is Inter Symbol Interference: the signal of one bit overlaps with another one and as a result U2 samples the wrong value. You can try to take a look at the eye pattern of PI. Try to see if the error is specific to a given signal in the PI vector or if it's random. But you can pretty much discard hold violation issues. A third possibility: the problem is noise related and it's also happening at 1 MHz, you just haven't noticed it yet.
