14 years agoHow to constraint my design using TimeQuest?
I am looking for some help to constrain my design. I've never done a timing constraint and my understanding of the subject isn't very deep at all. An overview of my design: it consists of a 72 ...
14 years ago --- Quote Start --- Could you provide an example? --- Quote End --- Sure, you use the same component, with a slightly different connection:
sync1 : sync
generic map(
RESET_STATE => '0'
port map(
clk => clk,
rstN => nRESET,
d => '1',
q => nRESET_sync
So how does this work? Well, when nRESET is low (active), the registers internal to this synchronizer are immediately cleared and output '0', i.e., the nRESET_sync signal is asynchronously asserted. When nRESET is high (deasserted), the synchronizer chain starts to synchronize the input d, which in this case is a '1'. After a couple of clocks, the '1' appears at the synchronizer output, and viola, the nRESET_sync signal deasserts synchronously. Cheers, Dave
