14 years agoHow to constraint my design using TimeQuest?
I am looking for some help to constrain my design. I've never done a timing constraint and my understanding of the subject isn't very deep at all. An overview of my design: it consists of a 72 ...
14 years ago --- Quote Start --- You should run reset through a reset synchronizer, i.e., a synchronizer that asserts reset asynchronously, but deasserts it synchronously, and then apply a false path. The reset and recovery time for the registers internal to the design will then be analyzed with respect to the synchronous deassertion of the reset signal. Cheers, Dave --- Quote End --- Could you provide an example? At the moment, I'm syncing signals like this:
sync1 : sync
generic map(
RESET_STATE => '0'
port map(
clk => clk,
rstN => nRESET,
d => sck,
q => SCK_sync
); I also read up on your byteblaster example but I don't think that implements a reset synchronizer.
