xytech
Contributor
7 years agoHow to connect one PCIe Reference clock to TWO GXB banks in Arial10?
Hi there, We use 10AX057H3F34E2SG, one PCIe x8 GEN3.0 link connect to PC's PCIe node. PC will provide one PCIe Reference clock 100MHZ. Since each GXB bank contains 6 transceiver-channels, TWO GXB ...
- 7 years agoFor PCIe Gen3x8, you will be using 8 transceiver channels. However, you only need one PCIe reference clock. The reference clock will be connected to 1xATX PLL and 8 CDR of 8 receiver channels through internal clock networks (within FPGA). Quartus Prime will handle the internal clock connection. All user need to do is specify the Pin where the PCIe REFCLK is to be connected. Regards, Nathan
xytech
Contributor
7 years ago.
