13 years agohow to connect analog input directly to FPGA Altera board?
hi;
I want to implement Sigma Delta ADC on Altera DE1, i wrote the code and run on QuartusII; now i want to know is it possible to connect the analog input directly to the board? as in my code the input is introduced as signed [7:0] so my original analog input should be converted to the type signed [7:0] before enter the altera cycloneII core is this conversion possible on the board? at the end how can i get my digital output from the board and analyze it? your guidance is very appreciated. thank you12 Replies
Thanks Dave; very useful help :)
Althoug Cylone II has differential LVDS receivers, they don't have a specified common range that would be well suited for the intended purpose. Thus an external comparator would be the preferred solution. On the other hand, I guess that the X competitor's LVDS inputs don't have a considerable better common mode specification and the said eval board SD ADCs rather depend on typical data than specified behaviour.
