12 years agoHow to configure an EPCS with a .rbf file?
Hello, I am using an IP SPI core to communicate with an EPCS128 device and write a specific .rpd file into it. It works fine! However, a .rpd file is too big (16MB), so, I tried to write a ....
12 years agoIts been a while since I played with EPCS, but I recall that you need to be using the .rpd file format, and there is a bit-order change required for programming SPI flash.
I believe this is all discussed in the SRunner documentation. https://www.altera.com/download/legacy/srunner/dnl-srunner.html Cheers, Dave
