15 years agoHow to config GX transceiver as DisplayPort PHY receiver?
Hi~
There isn't any DisplayPort item in MegaWizard . How to config GX transceiver as DisplayPort PHY receiver?6 Replies
I'm also trying to implement Displayport and have many questions. Did you suceed with Displayport? I would be very glad if I could ask you some questions. Or did anyone else implement displayport without a softcore?
Oliver - Altera_Forum
one of Altera's partners is offering IP for DisplayPort
I know but I would like to do that without any IP.
Which device are you using? Is it Stratix GX?
Ah sorry, forgot to say that, it's a Cyclone 4 GX.
You can implement Display Port using the ALTGX MegaWizard Plug-In Manager =>
- Select 'ALTGX' and the 'Basic functional mode' within the ALTGX MegaWizard.
- Select 'Receiver Only' as the operation mode. Specify the number of channels, data rate, input clock frequency as per your system requirements.
