16 years agohow to combine two modules into one?
hi guys i'm trying to combine two modules into one main module. that will connect both of them and create signals to go to one of them (like c in module 2 in the example) in the first th...
16 years agoIf you use VHDL, searh for Component and port map.
You can also try to use a schematic, you create a bloc of your modules and you link theme with cables...
