10 years ago
How to combine two different quartus projects?
Hello everybody!
I have 2 different quartus projects, one is for Nand flash controller and the other is for USB interface.
I have to combine both of these so that I can use the USB interface to read data from and write data to the Nand flash.
How should I do this. I am using quartus 10.1 and I have included components in both the projects using SOPC builder.
Thanks in advance..
    Hey! I imported nand flash files to usb project using the "add or remove files" option in project navigator. I wrote a top level where I instantiated both nand and usb components.
    It's working fine. Thank you very much to both of you for your time and advice...
    you're probably better off starting a new project that includes all the files you need.
    You'll need some form of top level linking them together - if they have the same interface spec then you can probably just connect them to each other, otherwise you'll need something (either code or QSys project) to connect them together.
    --- Quote Start ---
    I believe you cannot directly merge two Quartus projects. You might need to create a new project, then port over the IPs or instances required into the new project. You should consider if the size of FPGA as well.
    --- Quote End ---
    Hey! Thank you bfkstimchan.
    If I create a new project, how should I combine the components which I have created separately for nand and usb interface?
    If I'm not creating a new project and wish to import files, then,
    Can I add the files of Nand project into the USB project using "add or remove files" option in project navigator?
    Else, can I write a top level and call both USB and the Nand flash files as components(port mapping)?
    These are just various ideas I have, I'm not sure it might work or not. Just asking your opinion.
    Any advice is welcome..
    Also, what if I make the Nand Controller project as a custom component in SOPC and then add it into the usb's sopc?
