10 years agoHow to combine two different quartus projects?
Hello everybody! I have 2 different quartus projects, one is for Nand flash controller and the other is for USB interface. I have to combine both of these so that I can use the USB interface to ...
10 years agoI believe you cannot directly merge two Quartus projects. You might need to create a new project, then port over the IPs or instances required into the new project. You should consider if the size of FPGA as well.
