11 years agoHow to choose FPGA for converter control?
Hi to everyone, For the purposes of a project, I have to find a proper FPGA but I have never used one before. So I ask for your help. I briefly know and understand how to program an FPGA etc bu...
11 years ago --- Quote Start --- You can design your own comparator & PWMs using Verilog/VHDL. It is so simple, if you know these languages. However you may use Megawizard from Altera Quartus to generate comparator. There are on-line codes also available. --- Quote End --- I understand, but we are looking for something very easy and fast to be developed. Also the knowledge of Verilog/VHDL is a detergent factor. I will check Megawizard. SoCs are commonly used for power electronics because FPGAs and their vast capabilities are a little more complex. I will check DSP builder that seems easier... --- Quote Start --- For the FPGA part, I think even the simplest parts will suffice your application. Your timing requirements are not so tough. A CPLD I think is enough. --- Quote End --- I think so, but I have to talk with other colleagues justifying my decision with some specifications/tables/data etc. Maybe the white papers are ok... I am wondering if Altera has some FPGAs with SoCs that maybe have some peripherals. I did not manage to find something. Thank you for the immediate answer...
