11 years agoHow to choose FPGA for converter control?
Hi to everyone, For the purposes of a project, I have to find a proper FPGA but I have never used one before. So I ask for your help. I briefly know and understand how to program an FPGA etc bu...
11 years agoYou can design your own comparator & PWMs using Verilog/VHDL. It is so simple, if you know these languages. However you may use Megawizard from Altera Quartus to generate comparator. There are on-line codes also available.
For the FPGA part, I think even the simplest parts will suffice your application. Your timing requirements are not so tough. A CPLD I think is enough. You need to design your comparators/PWMs first. Then synthesize them using Quartus on some CPLDs. Finally you will know which part fits your requirements.
