14 years agoHow to check clocks using SignalTap II Logic Analyzer?
Hi all, I am learning how to use Signaltap II logic analyzer using this tutorial: http://www.altera.com/literature/hb/qts/qts_qii53009.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=design%20debugging%20...
14 years ago --- Quote Start --- To see the clock in the Signal-tap A higher sampling input is needed to sample may be (3 to 4 times more frequency than the clock you want to see) --- Quote End --- Thanks kalyansrinivasm for your advice. How do you come to know that the sampling clock must be 3 to 4 times higher in freq, if it is stated somewhere or just your experience?
