14 years agohow to change an inner signal from A pin to B pin?
for example,i had assigned signal_s to A pin. after fitting ,i found this signal_s should connect to B pin. so ,i have to edit the layout of design ,to change signal_s from all elements it have conn...
14 years agoWel no..you will have to P&R again..even a small change in ur qsf will ask of a recompile...offcourse if u wana do timing analysis then its mandatory that after a change to your setup you have to do mapping and fitting all over again..you have made a change and in order that your design accepts it a recompile is neccessary..
