14 years agohow to change an inner signal from A pin to B pin?
for example,i had assigned signal_s to A pin. after fitting ,i found this signal_s should connect to B pin. so ,i have to edit the layout of design ,to change signal_s from all elements it have conn...
14 years agothanks for your reply. you mean a signal in a placed and routed design , to be connected to another pin,without any change to other P&R logic , without a new synthesis and a new fitting, this can be realized just to do a new pin assignment in script?
