14 years agohow to change an inner signal from A pin to B pin?
for example,i had assigned signal_s to A pin. after fitting ,i found this signal_s should connect to B pin. so ,i have to edit the layout of design ,to change signal_s from all elements it have conn...
14 years agoyou should be able to change this in the Pin Planner. Alternatively you can look for the pin assignement in the Assignment Editor and change it there.
