8 years agoHow to build object libraries and assembly Macro-Instructions libraries?
For bare-metal application I need to build libraries of object files and libraries of assembly macro-instruction.
I look for information in documentations but I could not find anything. Thanks for your help. Kind regards Jerome3 Replies
To create a new object library it necessary tu use ARMAR tools :
https://developer.arm.com/docs/dui0476/g/creating-libraries/creating-a-new-object-library Once the library is made it's necessary to declare it in project property --> setting-->ARM Linker --> Libraries --> User libraries files. Jerome - Altera_Forum
Thanks a lot for your fast reply. The online training courses cab help me a lot. Today I’ve already created a start project with GCC compiler and ARM compiler. I saw the HwLib in the following directory: C:\intelFPGA_pro\18.0\embedded\ip\altera\hps\altera_hps\hwlib\include\hwlib.h These libraries are made for c language and I suppose I will have to redistribute it in binary form. But my question was different; I need to build my own macro-instructions libraries using an archived library (BFD ar-compatible for example). It seems that is possible with the GNU compiler but not with ARM compiler. My question was; how to create an archived library of macro-instructions with the tools DS-5 AE. This library will be loaded by the .mlib directive of GNU assembler (for example). Thanks for your help Jerome - Altera_Forum
Hi Jerome,
Go through the online training. https://www.altera.com/support/training/course/osocbarehwlib.html Kindly refer to the link below https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_bm.pdf It is probably helpful as you might be hoping. Thanks.
