12 years agohow to build 4 serial inverters
I want to build 4 serial inverters but at last when programming the FPGA quartus automatically fixes it as if no inverters exists.how can I do some thing to ignore this auto fixing?
--- Quote Start --- I want to build 4 serial inverters but at last when programming the FPGA quartus automatically fixes it as if no inverters exists.how can I do some thing to ignore this auto fixing? --- Quote End --- altera has provided various attributes useful in controlling fitter. for comb. nodes(wires) try this attribute: signal invert : std_logic; attribute keep: boolean; attribute keep of invert: signal is true; apply to all relevant wires in your chain. - Altera_Forum
Thank you for the code but I don't know how to apply it to my nodes in quartus.would you please help about that?
--- Quote Start --- Thank you for the code but I don't know how to apply it to my nodes in quartus.would you please help about that? --- Quote End --- You don't apply attribute to quartus. You add it to your vhdl code. I have already done it for you. Juat change name of "invert" to your signal name(s). insert where you declared that signal
