14 years agohow to automatically program using the usb blaster?
Hi, we are working with altera device that we need to program each time we power the board and it done alot and each time we need to program using the altera blaster program ,open, select file (th...
10 years agoHI, I also am seeking an API in order to integrate USB blasting into our test software. the command line command helps, but an API would save some operator intervention.
Is there an API? There must be a solution for aiding factory firmware programming. Labview?
