14 years agohow to automatically program using the usb blaster?
Hi, we are working with altera device that we need to program each time we power the board and it done alot and each time we need to program using the altera blaster program ,open, select file (th...
14 years agoIsn't there a flash memory connected to the FPGA on your board? If there is one, you only need to program the flash once. Then every time at power on, the flash will automatically load the programming file into the FPGA.
