14 years agoHow to add path to Modelsim to correct "the design unit was not found"?
Dear all, Modelsim ASE says: Error: (vsim-3033) ./submodules/q_sys_altmemddr_0_phy_alt_mem_phy.v(2925): Instantiation of 'cycloneiii_io_obuf' failed. The design unit was not found. How to ...
14 years agoHi jame.song,
Can you post a small code example that shows the error? Or post the error message output by Modelsim. Do you know that your setup is correct? For example, run one of the simple Modelsim examples I've posted, eg., http://www.alteraforum.com/forum/showthread.php?t=32386 or this one http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial (the first is VHDL, the second is Verilog/SystemVerilog, so may be more applicable to testing your setup) Cheers, Dave
