14 years agoHow to add path to Modelsim to correct "the design unit was not found"?
Dear all, Modelsim ASE says: Error: (vsim-3033) ./submodules/q_sys_altmemddr_0_phy_alt_mem_phy.v(2925): Instantiation of 'cycloneiii_io_obuf' failed. The design unit was not found. How to ...
14 years ago --- Quote Start --- Error: (vsim-3033) ./submodules/q_sys_altmemddr_0_phy_alt_mem_phy.v(2925): Instantiation of 'cycloneiii_io_obuf' failed. The design unit was not found. How to add the path so that Modelsim can find the cycloneiii_io_obuf --- Quote End --- That sounds like a Cyclone III low-level component. Usually those types of things are in quartus/eda/sim_lib/cycloneiii_atoms.v, which is pre-compiled for Modelsim-ASE. However, I just searched the sim_lib/ folder and could not find that component (11.1sp1 installation). If you can find where that component is located, then you can add the folder with the vlog +incdir+ option (see vlog -help). Cheers, Dave
