Jiayi_H_Intel
4 years agoHow to access QSPI Flash from HPS f2h interface
Hi expert,
I am using Stratix 10 SoC board. And my FPGA logic needs to access flash.
In my setup, HPS boot from SD card not QSPI Flash. And QSPI locate at 0xff8d2000 in HPS's map.
I connect my...
aikeu
4 years agoExample of working as below:
Jiayi_H_Intel
4 years agoHi Aik Eu,
Thanks for your reply. So in conclusion, the only way to access qspi flash is through sf cmd in boot stage. The function of sf cmd is to move data between flash and memory. And it is not allowed to access flash from FPGA side by F2H port. Is that correct?
And much thanks for your help.
