How to access QSPI Flash from HPS f2h interface
Hi Jiayi_H_Intel,
When u-boot boot up, in u-boot type help. Check for a command which is bridge. Then select bridge enable and see any difference.
Aik Eu
- Jiayi_H_Intel4 years ago
Hi Aik Eu,
I tied your suggestions, seems no difference. Can you please help?
Here are details of my design and test step:
I use jtag master to access hps's f2h interface:
Arm device tree is:
In arm uboot boot up terminal, I type "bridge enable", and then "boot" for default boot.
In system console:
set service_paths [get_service_paths master]
set master_service_path [lindex $service_paths 1]
set claim_path [claim_service master $master_service_path mylib]
master_write_32 $claim_path 0xff8d2000 0x1234master_read_32 $claim_path 0xff8d2000 0x1
Read returns 0x0. So my write to flash is not successfully.
Can you please help with that?
