How set timing constraint for such clock
- 4 years ago
First, I would make uadc_sclk be a reg variable and not a wire.
Then, you have to add timing constraints for your derived clocks. For example, I have this in my .sdc file for a design:
# Input 50MHz reference clock create_clock -period 20.0 -name CLOCK_50 [get_ports {CLOCK_50}] # Created clocks based on PLLs (CPUCLK = 80MHz) create_generated_clock -source {pll|altpll_component|pll|inclk[0]} -divide_by 5 -multiply_by 8 -duty_cycle 50 -name CPUCLK {pll|altpll_component|pll|clk[0]} # Created clocks based on logic (RTCCLK = 25KHz) create_generated_clock -source {pll|altpll_component|pll|clk[0]} -divide_by 5000 -duty_cycle 50 -name RTCCLK {dk8ea_clock:rtc|rtcclk}where the clock RTCCLK is generated via this code:
// system clock divider to RTC clock rate reg rtcclk; // rtc clock reg [31:0] rtcdiv; // rtc prescale clock divisor always @(posedge clk) begin if (reset) begin rtcdiv <= #TPD 32'd0; rtcclk <= #TPD 1'b0; end else begin rtcdiv <= #TPD (rtcdiv == PRESCALE-1'd1) ? 32'd0 : rtcdiv+1'd1; if (rtcdiv == 32'd1) rtcclk <= #TPD ~rtcclk; end end
"Node: nios:nios_0|mcu_uadc:mcu_uadc_0|read_cnt[2] was determined to be a clock but was found without an associated clock assignment"
Seem like above error can be caused in two ways:
1) A clock assignment was determined to be invalid, so its source objects no longer have a clock associated with them.
2) When analyzing the netlist, the node was found feeding a clock port with no other clocks feeding it.
You can use the derive_clocks command to automatically find all clock nodes in the design. Also, for any clocks that were ignored, review the warning or error message associated with the command to prevent the clock from being ignored.
Once all the node with unassociated clocks are identified, you should apply you timing constraint for derived clock e.g. create_generated_clock
Hope that helps.
Thanks a lot!
