myrfy001
2 years agoHow many different frame can a F-Tile Ethernet IP output in one beat in segment interface?
Hi, from the PDF document, It says that a 400Gbps Ethernet controller can use segment interface, new frame can start at 8-Byte aligned position. My question is, how many ethernet frames can occur i...
ZiYing_Intel
2 years agoHi,
Do you still have any question about the case?
zying
- myrfy0012 years ago
Thanks. Your answer is almost the same as my assumption. But I want to know the answer that you mentioned "IP vendor's documentation will provide the most accurate and relevant information", I have read almost the whole document, but I don't have find out the accurate description about the behavior for RTile IP.
