16 years agoHow many AltAccumulates?
I am looking to instantiate 48000 64bit AltAccumulates in a Cyclone 3 device running at a 200MHz data input rate into the FPGA i.e this is the frequency required to switch between them, although each accumulator will only be updated at a rate of approx 10KHz. Am I being unrealistic? I can achieve much the same thing using the FPGA internal memory and adders, but it requires more internal memory than the largest cyclone 3 devices provide. I can get the results I want from Stratix devices, but the cost penalty is unacceptable. I realise I can use external DDR2, but I only require 3 MBits, so it seems rather wasteful, leave alone the increased complexity. Board space is also premium. I have tried implementing the required memory in logic and Quartus runs out of memory despite the /3GB setting in windows and stops - generally after several hours of trying. The biggest issue I have with the Altaccumulate is the time it takes to compile - I haven't managed to get it to complete yet - the longest I have left it is 28 hrs. To instantiate 2400, 1/20th of what I need takes 3 hrs on a 3 gig dual core win xp with 4GB of Ram. I'd be grateful for any advice / suggestions Many Thanks Duke1 Reply
If the accumulator/register design doesn't fit the internal RAM, it can never fit register resources. No use in trying further. If internal RAM isn't sufficient, only external RAM (at best SSRAM for it's fast interface) can do. EP3C120 actually has enough RAM.
A simple calculation furthermore clarifies, that more parallelization (at least 4x64 Bit in parallel) would be needed with external RAM.
