16 years agoHow long does the FPGA complete the initialization?
Hi dears: I found below information inside Altera configuration handbook: "By default, the internal oscillator is the clock source for initialization. If the internal oscillator ...
16 years agoAfter POR time has expired (the value is specified in the device handbooks), the initialization time requirement is mainly for reading the serial or parallel configuration device. The frequency range is also specified (the internal or external clock in case of AS configuration), the configuration stream size depends on your design.
