12 years agoHow do you connect to the DEV_CLRn pin when it is enabled
I have enabled the device-wide reset (DEV_CLRn) to allow the input signal to reset all my registers. How do I connect to this global input so I can use it for other logic in my Verilog code?
12 years ago --- Quote Start --- If you opt DEV_clr_n as reserved pin for clearing registers, that is what you did, you can NOT use it in your design as a user signal. If you want to use this pin, set it as a "user I/O", in your TOP LEVEL ports, add "DEV_CLRn" input (user input) and in pin planner assign this user "DEV_CLRn" to "DEV_clr_n" pin (=B3 for Cyclone II). ReThink your equation : I don't know Verilog, but I guess assign signal1 = DEV_CLRn & signal2; is "signal1 receives DEV_CLRn AND signal2" So if DEV_CLRn = '0' then signal 1 = '0' --- Quote End --- Yes, but if I make it user I/O, it will no longer do the asyn reset to all the flops in the part. I still want that plus I want to use the input for other things.
