12 years agoHow do you connect to the DEV_CLRn pin when it is enabled
I have enabled the device-wide reset (DEV_CLRn) to allow the input signal to reset all my registers. How do I connect to this global input so I can use it for other logic in my Verilog code?
12 years agoIn Quartus > project > settings > assembler (or elsewhere), you get an option for DEV_CLR_n pin : "Active low device clear registers" OR "user I/O pin", opt for the first.
You don't have to code something : it is already connected to (asynchronous clear of) registers, I think. Keep in mind that Quartus may add NOT gate push back, it depends of at which value do you clear your signals AND how Quartus synthesizes (have a look at warning messages). May an other one be more expert on that.
